Monday, October 29, 2007
Time to sort the software
Why no pictures of printed bits recently? Well, we're sorting out the software. Part of this involves sorting out the development tools so we can sort out our software, which has resulted in yours truly abusing the Debian packaging system to produce 2.7.4 SDCC DEB files. If anyone can make a better go of it, please do. If you want to see what I did to it, the files are online here: http://reprap.org/bin/view/Main/SDCC
I've also rebuilt GPUTILS: http://reprap.org/bin/view/Main/Gputils
Vik :v)
Labels: , ,
Thursday, October 25, 2007
RepRap visits a FabLab
Here are Ed and Adrian discussing the machine with Joseph Okor from the FabLab in the South South End Technology Center in Boston. The Lab's Ed Baafi is behind the camera.
We hacked in an old PC power supply they had lying about to get it running.
Then it crashed :-(
However, this was a FabLab, so they soon equipped Adrian with a soldering iron, and he unplugged the extruder and re-soldered the lead to the thermistor which was causing the problem.
And we were able to make them the start of the shot glass before it was time to pack up and go home.
Thanks to Ed and Joseph, and also to Neil Gershenfeld whom we had met there earlier in the day, for their hospitality. We shall send them a RepRap extruder so they can experiment with integrating it in one of their systems.
Open-source is so cool...
Tuesday, October 23, 2007
The latest from Adrian
The Canadian Broadcasting Corporation did an interview with Adrian over a Skype connection.
http://www.cbc.ca/spark/blog/2007/10/interview_with_adrian_bowyer_3.html
The voice quality was exquisite, though there were a couple of drop-outs. As always, Adrian gives a very good interview on RepRap.
Here is RepRap (and me) at Pop!Tech - one of the most eclectic and entertaining conferences in the world. Thanks to them for the invitation to present the project. RepRap was in a session with Matt and Jessica Flannery's Kiva, which is another extraordinarily good idea - visit their website too.
We made an impression, and got a RepRap version 1.0 "Darwin" set up and working in the conference coffee area, where it excited considerable interest (especially when the extrude head jammed for a few minutes with an expensive crunching noise...).
Sunday, October 21, 2007
X-axis idler assembly in PLA
Just for kicks, I printed out a couple of belt clamps and a pulley. Oh, and about 95% of an X-axis restraint (software crash, blue-tinged air etc.) but it looks like we're on our way to starting an X-axis here.
I've switched to a 0.78mm nozzle now, and the new shape is an improvement in preventing strings - or at least shedding them quickly - but not much so. Also having a few problems with PLA not adhering to my new machine bed so well. Hopefully a good wipe-down with acetone and a scrape with a wire brush (for the Reprap, not me) will improve things.
Vik :v)
Labels: ,
Saturday, October 20, 2007
X-Idler Bracket Continued
OK, here's the tidied up version. I had to ream out the vertical holes by hand, the horizontal holes were fine and just needed de-stringing. I have seen how threads of molten plastic climb up the curved surface of an acorn nut nozzle and I'm modifying one to see if I can reduce the stringing. The holes in general were smeared somewhat, mostly due to a soon-to-be-fixed software bug which resulted in the extruder not being turned off at appropriate moments.
In the previous post, you can see the part starting to curl like a king-size mattress being stuffed into a queen-size fitted sheet. The curl is not very pronounced, but did distort the 8mm holes making the insertion of an 8mm rod very tight indeed - you can see shavings on the end closest to the camera. The nuts fitted into the rectangular slots at the top without a problem. The other holes were a little tight and required gentle persuasion to drive the nuts home - a bolt and very large washer was used to winch them in.
What didn't fit was the nut down the channel in the 8mm hole. My reaming didn't clean that out enough and I had to resort to a dremmel tool.
It near enough works and I'll be building it into a Reprap as soon as I can.
I'm extruding in 0.55mm layers, 1.62mm outline size and 0.73mm infill size from a 0.86mm nozzle. Max x-y movement speed is set to 238. This gives fat outlines, but because of the jerky movement between points by the head, curved lines are fatter than straight lines and the slow speed minimises the difference in width.
A very respectable 0.5mm width wall was printed by mistake during a buggy phase of this printout when the nozzle moved without being turned off, but this is good as it shows what the hardware is actually capable of - even with a 0.86mm nozzle.
Vik :v)
Labels: , , ,
Friday, October 19, 2007
X-Idler Bracket Printed
Here's the pretty side of 11 1/2 hours of Reprapping. You can see that the PLA started to curl - I'm not cooling layers here so I might have to get that working again.
The paper tube is because I realised half way through that the hole for the axle was not Reprap-friendly as it was not pointed. So I quickly rolled up a bit of the nearest thing to hand (a Catalyst compliments slip as it happens) and poked it in the 3/4 complete hole. I had to roll it around a bit of 6mm rod as a guide to slip it in.
The Reprap-friendly hole shape is quite clear in the top right corner. The loops on the left edge are caused by the nozzle erroneously seeking warmth in its corner due to temperature reading bugs.
Anyway, I'll tidy it up and take some pretty photos tomorrow. Kinda tired right now.
Vik :v)
Labels: , ,
Wednesday, October 17, 2007
Having a little wine
Continuing on the beverage container theme, we now have a wine glass. Actually, we now have two. Measuring the second shows a 72.9mm height, compared with the expected 70mm so I have tweaked the Z scaling accordingly.
Why the beverage glass fetish? Well, apart from being an old soak, they're not very taxing on the construction algorithm and it's obvious when they are either not watertight or asymmetrical. Also, I wanted to do overhangs, and a thin-stemmed glass looked to be a good demonstration of the ability of the RepRap to do overhangs.
Vik :v)
Labels: , ,
Friday, October 12, 2007
For those who prefer mixers
One martini glass. Now the reprap's head doesn't bob around, I can make some surprisingly delicate structures. This object was printed without any forced cooling - or cooling delays - at all.
Yes, it's watertight.
Vik :v)
Labels: , ,
First RepRap'd Z-Axis Pulley Rim
Here's a photo of the Z-axis pulley rim that fits on top of the Z axis gear. I've pulled off all the stringy bits and reamed the holes out with just a drill bit held in my bare hand to clear the thin cruddy bits out. As you can see, it's not too shabby.
I've tried printing a corner bracket and got about 70% the way through before a new and unexpected software state was encountered. Ahem, cough. Beyond my ken, but Adrian will be back soon...
Anyway, here are the modifications I did to the Darwin to get PLA coming out.
A. Oily rag in holder to lubricate filament.
B. Large 12V motor to push filament through.
C. Fan to stop polymorph motor holder melting.
D. Polymorph saddles to stop excessive rotation of carriage.
E. Clamp to apply extra pressure to filament.
X. That's a label so I remember which one is the X-axis motor...
You can't see it in this photo, but also I flopped the extruder "umbilical cord" over to the side so that it doesn't tangle with the filament feed.
Vik :v)
Labels: , , ,
Wednesday, October 10, 2007
RepRap goes to MIT
Zach, Sebastien, Ed and I had a paper on RepRap accepted by the 2007 Mass Customization and Personalization Conference at MIT. Ed and I registered for the conference and we decided to bring Darwin along to show as well as presenting our paper.
After no trouble at all with airport baggage security at Bristol International (thanks to them for being tech savvy and non-jobsworth), I got the machine in bits in among my socks to Boston. Here's Ed putting it together in my hotel room:
And here's us with Darwin building the famous Vik minimug in the conference lobby in a pic taken by Zach's friend Caitlin:
As you can see only one of us fully realizes the terrible gravity of the situation...
Saturday, October 06, 2007
Tha intakes are clogged wi' dust, Capt'n
The standard CAPA filament is reasonably pliable and doesn't form dust. PLA, on the other hand does. The reason for a recent extruder jam was that the bearings had filled with PLA dust. I wondered if we might open up the extruder a little behind the screw drive to let dust and debris fall out?
Update: Dust prevented and feed improved by lightly lubricating the filament with SAE 30 oil.
Vik :v)
Thursday, October 04, 2007
PICs Reading USB Drives
We've kicked around the idea of a RepRap being able to store parts on a USB drive so that no PC is actually needed to print things out. It's a little esoteric and not a near-future priority, but for those into such things this article describes how a PIC can be interfaced to a USB Flash drive using a VNC1L Vinculum controller IC:
http://dataweek.co.za/news.aspx?pklNewsId=26407&pklCategoryID=34
Vik :v)
Labels: , ,
Wednesday, October 03, 2007
RepRaps by the ton III
As all you avid RRblog followers know, one of the things we've been doing is looking into using soft moulding to allow us to make RepRap components from the rapid-prototyped masters to sell in the RepRap online shop as a stopgap until there are enough RepRap machines out there to be making stuff directly.
I have now put complete instructions on how to do this on the wiki here.
Comments [Atom]
