Tuesday, April 29, 2008
Gripping Stuff - The Extruder Clamp
The extruder clamp was missing from my pile of parts in the "complete" RepRap, so I've remedied that. Took about 12 hours to print in PLA. As you can see, the clamp grabs a 16mm PTFE rod very well even without the clamping screws. There is also a channel in the clamp to take a 4mm self-tapping screw with which I intend to further secure the PTFE.I was short a few diagonal bracing brackets, but those are no problem and shouldn't take more than a couple of days to run off.
I'm now also short an X-axis flag 'cos I put a bench vice down on top of it...
Vik :v)
Labels: clamp, extruder, reprap
				This is great!
I'm really excited for the first RepStrap-printed RepRap to start printing for itself.
Have you been logging the time it takes to print each piece? What speed are you extruding at? Those numbers might be interesting.
				Kyle, the speed varies between 8cc and 6cc per hour, depending on the density I'm using. Parts that need strength need a higher density
The RepRap GUI software will provide an estimation of the time it will take to print an object.
Vik :v)
Vik :v)
				Wow that's a great print. I really need to sit down and work outs wrong with  my extruder so I can start printing.
				greenarrow, you're doing great with the plotter stuff. I too reckon that should be on the Live CD.
Vik :v)
	Vik :v)
