Wednesday, November 18, 2026
RepRapMicron 106 - Tuning An Axis Driver
I've finished off the video I started just before Sci Foo. This one shows how to finish off and align the Axis Driver, and how to roughly calculate the number of steps per micron.
Tuesday, November 17, 2026
Sci Foo Fallout #1 of n - "This isn't good."
Sci Foo was absolutely amazing and I'm not going to plough through it in one shot. There were many problems, and the organizers dealt with them very well. In particular, I turned up with an NZ "Opened By Border Security" sticker on my suitcase. This isn't good. Not my first rodeo.
Seeing my stuff headed for a plane's cargo hold, Insecurity Services opened it for a look. Unfortunately they did not pack it back in as I had and two of the Axis Driver modules were smashed on arrival. I had packed one spare, but did not anticipate that much carnage.
So many thanks to Sami of Google who printed me a new set of Axis Driver parts. Much better than my impromptu repair with duct tape and superglue (worked surprisingly well, but unsurprisingly not great). Sadly, I did not pack very well for the return trip. Truth to tell, I was in a great rush (literally throwing stuff into suitcase off the demo stand to catch the airport shuttle) and most of it was old version. So here's the utter carnage that made it home:
Know what? It's all just 3D prints, and I can just print a set of better ones.
"Why Not Use Springs Instead Of Loom Bands?"
I am aware that the use of Loom Bands is controversial. In short, Loom Bands provide tension over a longer distance than springs of equivalent mass and cost do. But I understand why some want springs. So:
I'm putting this up now because I'm clearing the decks after Sci Foo and this happens to be on the bench. The top of the extension spring is hooked over a convenient M3 screw. The lower end is held in the more confined area around the Drive Screw with a thin 'O' ring slipped through the spring's loop.
Two things: The spring needs to be "boosted" higher than the usual Loom Bands. Any attachment system has to attach as close the the Drive Screw as possible so as not to create torsion in the flexures. This is why Loom Bands are fitted where they are, and in pairs.
As you can see, this might work, but the shape of the Nut Bar will have to change so that it does not collide with the spring. This varies with spring dimensions too, and it's hard to get ones of any particular size. This one is 5.5mm x 25mm in 0.5mm dia wire.
I don't propose to fix this myself (unless benefactors appear on my ko-fi page...). I'm happy replacing Loom Bands every few months, particularly with the new design that makes that easier. But it's Open Source, I put it all on 10mm centres for a reason, and let me know how you go. Here's a couple more angles just in case you want to do it:
Friday, November 13, 2026
In Singapore at Sci Foo
I got here with a PIKA. More or less. Two of the axes were smashed in transit. I brought one spare. Damn. So I made this repair to five flexures with gaffer tape and superglue:
It looks (and is) extremely janky, but it moves and will do until a friendly local prints another axis.
Thanks to the Hotel Momentus for the use of the room's tea tray for transportation...
Monday, November 09, 2026
Sci Foo Singapore
I feel extremely honoured to have been invited to Sci Foo in Singapore next weekend, coutesy of O'Reilly Media and Google. So I'm going to be kinda busy until then. Antony says "Hello."
Friday, November 06, 2026
RepRapMicron 105 - Axis Driver Assembly Video
Added a new video showing how to assemble the RepRapMicron PIKA V0.03 Axis Driver - the one with easier to install/replace anti-backlash bands. I get to set something on fire in this one too.
https://youtu.be/5TI-oAWuZNE
Thursday, November 05, 2026
Wax Actuator with 5 Micron Resolution
Just saw an interesting post which uses wax as a force mechanism for milli/micro-scale actuation.
https://www.youtube.com/watch?v=KF2R5GGfRHM
I have vague notions of doing something like this one day with the wax from an automatic greenhouse vent. Turns out, if you read the comments on the video and on Hackaday there are lots of reasonably common things that use wax as an actuation mechanism.
https://hackaday.com/2026/11/04/making-a-wax-motor-for-micrometer-level-control/
Here's a relevant quote....
"a gap of less than 5 µm was maintained over twelve hours, showing how precise this device can be if you can control the temperature that the wax is kept at. "
It is quite slow though - but food for thought.
Monday, November 02, 2026
PIKA Drive Nuts And Screws Video
Another YouTube video, on making and installing Drive Nuts and making Drive Screws if you don't happen to have M3 x 50mm plain steel or zinc plate cap screws hanging around. This one also shows the differences between the PIKA V0.02 and V0.03 frame.
Sunday, November 01, 2026
PIKA Entering V0.03
RepRapMicron PIKA has now left the current documented version behind and moved on to V0.03 - so if you want to get the files for building V0.02 you'll have to get them from before the V0.03 tag.
This happened because the PIKA Axis Driver is now sufficiently different to the MAUS Axis Driver that they no longer fit. The good news is that the PIKA driver is a lot cleaner, has fewer confusing holes, has easily replaced/installed tension bands, a simpler system for attaching Z flexures, and gives you a way to access all the stepper motor screws.
Changes a dropping piecemeal at present, but I've made a temporary downloadable of Printables https://www.printables.com/model/1894754-pika-v002a-sideband-axis-driver. Latest files look like this:
Thanks for debugging, Jon!
