Tuesday, November 17, 2026
"Why Not Use Springs Instead Of Loom Bands?"
I am aware that the use of Loom Bands is controversial. In short, Loom Bands provide tension over a longer distance than springs of equivalent mass and cost do. But I understand why some want springs. So:
I'm putting this up now because I'm clearing the decks after Sci Foo and this happens to be on the bench. The top of the extension spring is hooked over a convenient M3 screw. The lower end is held in the more confined area around the Drive Screw with a thin 'O' ring slipped through the spring's loop.
Two things: The spring needs to be "boosted" higher than the usual Loom Bands. Any attachment system has to attach as close the the Drive Screw as possible so as not to create torsion in the flexures. This is why Loom Bands are fitted where they are, and in pairs.
As you can see, this might work, but the shape of the Nut Bar will have to change so that it does not collide with the spring. This varies with spring dimensions too, and it's hard to get ones of any particular size. This one is 5.5mm x 25mm in 0.5mm dia wire.
I don't propose to fix this myself (unless benefactors appear on my ko-fi page...). I'm happy replacing Loom Bands every few months, particularly with the new design that makes that easier. But it's Open Source, I put it all on 10mm centres for a reason, and let me know how you go. Here's a couple more angles just in case you want to do it:
Comments: Post a Comment
