Wednesday, January 23, 2008
Update from he who feels like hammered sh...
			  I've taken the cutting board off the RepRap and given it a damn good sanding flat, checking it with a steel ruler like my old Design & Technology teacher showed me while I was busy wrecking his workshop. Adhesion improved, particularly for large areas. Not managed to print an X Motor Bracket properly yet.
The Y Bearing Housing I printed the other day broke when I put the insert in. I found that there is an area inside that gets no infill, and so the part is really fragile. I narrowed it down to a pretty damn minimalist debuggable shape and sent it to Adrian, the internationally famous geometry guru. A mere 8 points or 12 triangles.
Brain currently fried due to insomnia, my back is aching like hell through painkillers, and LinuxConf is less than a week away. Ohboy.
Vik :v)
Vik :v)
				We put a sacrificial thin layer of MDF on the main base so we can easily swap it for a clean one.
Take it easy Vik...
			Take it easy Vik...
				This is my sacrificial sheet. I just ain't ready to sacrifice it yet :)
Will see if Doc has "take it easy" pills. Usually they're "take with water".
Vik :v)
Vik :v)
				Sorry to hear you're having troubles, Vik.  I'd sure like to get some loose time to work on Reprap.  My day job, however, has been taking 16-18 hour days, 7 days/week since September.
As the Terminator said, "I need a holiday." It sounds like you do, too. :-(
				Supplements, Vic, supplements. CoQ10 is great stuff for stamina and energy. And try melatonin for the insomnia, it works good half-hour before bed time or so.
				I've got alpha-lipoic acid and acetyl carnatine supplements, normal multi-vitamins to counteract my beer-based diet (why are NZ multi-vitamins 10x the size of UK ones?) and some valerian for the insomnia. The cats go a bundle in the valerian too. After a while, they think the valerian lives in the teapot, and then wreck the teapot. It has got to the point where we bring a new one back from going on holiday.
Vik :v)
	Vik :v)
