Monday, May 15, 2006
Limits on the gear script not as bad as thought...
Turns out I'd managed to corrupt AoI or Java or both while I was writing the script.
I reinstalled both and I can now generate at least 48 tooth gears and helical at that.
I then decided to see if I could double that tooth count, so I went to 96 teeth and dropped the pitch angle to 14.5 degrees so that we didn't get weirdness in the profile.
That worked fine, too. I pushed it again to 128 but at that point the triangular mesh feature wouldn't turn the profile into a surface for me.
At 96 teeth you're talking about a 180 mm diameter gear if we are to keep the teeth at 3 mm. That's pretty big.
It's slow, but it works. :-)
![](http://photos1.blogger.com/blogger/1787/1159/320/48%20tooth%20helical%20gear.jpg)
![](http://photos1.blogger.com/blogger/1787/1159/320/96%20tooth%20helical%20gear.jpg)
These are going to be fun to print out :) Last night was a bit busy, but hopefully there will be time to do some fine tuning and testign of the Z axis tonight.
Vik :v)
Vik :v)
If you can do a helical gear, does that mean you could also do a helical shaft? Example: a 6" long, 1/2" diameter rod with 8 teeth spiraling up its length.
