Monday, January 26, 2026
V0.05 Axis Driver Assembly Hint - Band Retention
If you're assembling a V0.05 Axis Driver, insert all the nuts, then put the silicone bands on. You can hang them up out of the way on a couple of screws like this:
 (The blue bit and 50mm M3 screw was added after I'd hung the bands on, but it propped it up at a photogenic angle...)
Then you can pull them over the top of the Nut Bar once it is in place over the Drive Screw.
Comments: Post a Comment
