Friday, April 18, 2025
Hackaday "Jolly Wrencher" 1.5mm x 1.5mm
So the "Maus" RepRapMicron mechanism still works, and the electrochemically etched nichrome tip that I bent stood up to it all. That's a relief. I could deposit at much finer resolution in resin as I can get down to 15-20μm per pixel with that rather than the rather ragged 30μm pixels that the mechanical process of chipping away Sharpie marker creates. Not so visible for debugging but.
Still, this PNG to GCODE converter works well enough. Might be a convenient way of testing the conductive/semiconductive resins for arrays of LEDs or sensors etc. when I finally get hold of some.
Here's the Maus in the process of doing the print. I'm using the mechanism described here and Arduino/GRBL electronics. If you want to build one start here https://github.com/VikOlliver/RepRapMicron/wiki.
