Thursday, January 27, 2011
Improved Huxley design
I am working on an improved Huxley design.  This is slower than I'd like, owing to lack of time, but it's coming together.
A few key points:
  1. It's all being done in OpenSCAD - the files are in the RepRap svn repository under huxley.
  2. It uses printed sliding bearings that are screw adjustable, so they always fit exactly.  Further, you can compensate for wear.
  3. Other adjustments are done with shims.  Or small rectangles of paper...
  4. Rhys has found a very high torque NEMA 11 motor which I hope to use for my microextruder for it.
  5. I'm trying to design it for ease of assembly.  In particular, I'm trying to get it so that you can put things together in just about any order, and so that you don't have to take four things off to extract and replace a fifth.
The first version will have a moving Y platform, like Mendel.  But MakerBot have taken Ed Sells' idea of building on a conveyor belt and made it work, so I think replacing the Y motion with a belt will follow soon after.
    Labels: , ,
    Wednesday, January 26, 2011
    Conductive pastes take 453
    As ever, I'm constantly on the look out for nice conducting materials. I recently stumbled across a special powdered Nickel. What’s particularly interesting about it is that it is dendritic i.e. the particles are spiky rather than spherical. Essentially this means that when mixed with a polymer, the metal particles are more likely to touch each other so it therefore gives a much lower resistance.
    Apparently this stuff is typically used making conductive paints, so its readily available. I managed to get some filamentary powder thats about 2.35um in cross section and 15um long . In small quantities this costs about £95/kg
    A colleague and I crudely made a thin film that measures 100x100x1mm out of this powder mixed with liquid latex in a 1:1 ratio in terms of weight. The paste seemed sufficiently viscous that we could extrude it with a paste extruder. We embedded 9 electrodes in the film so that we could get repeatable readings. The total resistance between opposite electrodes came in at 0.8ohms, which is about a 9cm length spanning the film. I guess this is sufficiently low to be useful for a lot of low current applications.
    Labels: , ,
    Monday, January 24, 2011
    Filling in with the fillings
    I've recently been experimenting with the loading of various fibres into CAPA and PLA. This started out as simple strengthening for the 3mm PLA that I sell, but the addition of 20 micron x 1mm nickel fibres makes it conductive. Dunno how useful this will be yet but it certainly allows RFI shields to be printed.
    Then I hit on a brainwave: short polyacrylonitrile fibres. There are normally used to reinforce synthetic rubber. But they have another use: The feedstock for carbon fibre.
    My trick is to mix polyacrylonitrile and similar materials in with PLA or CAPA. This is then turned into filament, which in turn is printed into an object on a RepRap - this tends to align the fibres.
    The object is then encased in a ceramic and heated to the vapourisation point of the PLA or CAPA. You then have a ceramic mould stuffed with oriented polyacrylonitrile. Introduce an inert atmosphere and raise the temperature and you have a mould full of carbon fibre. This can be surface-activated in the usual ways, or coated with vapour deposition before being vacuum-encased in epoxy to form a complex, 3D carbon fibre composite object.
    Yes, I am looking for sponsorship :)
    Vik :v)
    Labels: , , , , , , ,
    Evolving the Prusa Mendel: Part 2
    Two weeks ago, Rob posted about some of the awesome stuff we've been doing with the Hacklab Reprap, a Prusa fork. I thought it might be worth while to bring everyone up to speed on what has happened since.
    1. A ground up redesign of z-motor-mount. It reduces the build time from 1 hour and 20 minutes to 30 minutes. It reduces the part count by two and gets rid of one rod.
    2. New designs of y-end-* reduce part count and build time.
    3. 3d printed nuts. You can also watch a video of them.
    4. Pics of y-end-* designed for threaded rod instead of belts, though this feature is in hiatus for now.
    5. There is now a mailing list for hacklab-reprap.
    Read More
    Rob's new y-end-motor design vs old
    Thursday, January 13, 2011
    RepRap MicroExtruder
    I have started to design a MicroExtruder for 1.8mm filament.  So far I have just got the non-reprapped parts, shown above.
    As you can see, it is about the size of the two end joints of my index finger.
    It is a miniaturised version of my standard extruder here, which was based on ideas from Nophead and others, with bits from me.
    From the top there is the filament (green - thanks Vik!)  then a length of 8mm diameter PTFE.  This screws into the brass nozzle with an M6 thread.  There is then a PEEK disc with two 2mm holes either side.  Those will take two M2-threaded rods.  The tension in these will resist the extrude pressure.
    The brass nozzle is threaded M4, and screws into a small brass heater block.  This takes the normal RepRap thermistor for temperature measurement, and is heated by an 8.2 ohm metal-film resistor rated up to 235 oC, which should give 16 watts at 12 volts.
    The filament hole down the PTFE and brass is 2mm in diameter.
    So far it is untested - watch this space...
    Labels: ,
    Monday, January 10, 2011
    The Emerging Economy of Home Manufacturing
    Hod Lipson and Melba Kurman were asked by the White House to write a report on the emerging phenomenon of home manufacturing.  It has recently been published and - as you would expect - it makes interesting reading.  You can access it here:
    Labels: ,
    Sunday, January 09, 2011
    Evolving the Prusa Mendel: Part 1
    Chris Olah and I have been developing a fork of the Prusa Mendel at over the past couple months with 3 major goals:
    1) get larger build volumes from a smaller printer footprint [we don't have much room at hacklab]
    2) reduce the printed and non-printed part counts
    3) increase the configurability of the Prusa Mendel
    Today we are able to show the first parts of the Hacklab RepRap - a simpler, smaller and more configurable Prusa Mendel. I'll leave the in-depth discussion to Chris but heres a couple pics to wet your appetite:
    Sunday, January 02, 2011
    Belt drivn extruder
    It occurred to me recently, after building two mendels, and printing way too much (including one of those mendels), that the weakest harware point in my Mendel was the gearing on my extruder/s.
    They always seem to have problems.
    I have problems with:
    *printing the teeth nicely/accurately,
    * getting the teeth to mesh,
    * keeping them meshed over time,
    * teeth wearing out or getting "chewed off"
    and the resulting printing issues these cause!
    So, I thought "I don't have issues with the XYZ axes anymore, so why not use the same principle/s on the "E" axis.?
    Result: A belt driven "adrians" extruder.
    I took a random "big" cog for a belt, and a semi-random "small" one ( ie matching), and put them on one of my extruder/s. It's awesome! I haven't "skipped" , or chewed a tooth or anything in ages!. It was a little fiddly sewing the belt together ( with a needle and thread ), but that's just because I'm too cheap to buy one the right size.
    From Reprap
    and a youtube link to it printing:
