Thursday, July 02, 2009
No-lathe extruder interior
Some were a little puzzled as to how the interior of the no-lathe extruder works. As I'm putting a few together, I took a photo showing how it combines the ideas of a simple locknut thrust bearing and a chopped-up drilled nut being used as the bearing behind the filament contact point. Files now online at http://www.thingiverse.com/thing:765.
Vik :v)
Labels: , ,
Nice work vik!
I'll have to try this one out
I've got a half-hearted attempt at an interrupt-driven speed controller firmware for a single opto endstop as a speed controller.
http://sites.google.com/site/renoirsrants/reprap/software-i-use
It works for the BitsFromBytes encoder wheel : it probably needs some tweaking for the timings for this version.
It's not currently tested properly but appears to work on my system.
I don't think you pinched the lock nut thrust bearing idea from me. I have never used or advocated one. Infact, you blogged it here in 2005, before I had heard of RepRap.
blog.reprap.org/2005/06/bolt-based-polymorph-pusher-mkii. More expensive, but still no lathe, and will last a lot longer.
The closest thing I have used is a ball bearing between two nuts for thrust and two acting as rollers at the pressure point. hydraraptor.blogspot.com/2009/04/dinosaur
Brane fale.
Sorry about that. I've edited it out.
Vik :v)
And typing fail on my front. The "More expensive ..." comment should be at the end of course.
Shame these comments can't be edited!
Comments [Atom]
