Monday, May 11, 2009
The No-Lathe Barrel & Nozzle
![](https://blogger.googleusercontent.com/img/b/R29vZ2xl/AVvXsEgtAdKasfFE7dLx0_yJdkNIW2sd-Xi_wn4Pv1Z_8w7vuNAjImOpaOTxp1nUwzPH1yyMZ2da9Rdy_CXUGNz2A9cMXOdeKQ_luuIQJlPzz2TSMWUCBvzEC6AlB6mQq0sBhypxTu9jW9nI/s320/dsc04758.jpg)
I Started by dismantling the telescopic aerial, removing the base and very tip so I could slide all the bits apart. Find the tube that is a snug fit on an M3 or M4 posidrive machine screw. Note that one of the ends of the tube has a shoulder turned over on the end of it that stops the other bits of aerial slipping through – this will be the nozzle end. Chop off 50mm of tube and smooth the cut end.
Economic note: More tubes with shoulders can be made by cutting lengths with a a pipe-cutter and gently hammering the cut end over, allowing one to make several barrels from one aerial.
![](https://blogger.googleusercontent.com/img/b/R29vZ2xl/AVvXsEgvl9gxkRbr0Wh0BCiqHhKhjANkOaWONkyw42XnzxL1QLUpFD_4K5B6GitXaKklUQVONeLcoTiudBkeUOWkY56AGREmfTsy7NLB_GVZ_nMDfgweR0J4o70oQtBMHvMtem5rjlgI4IGz/s320/dsc04746.jpg)
![](https://blogger.googleusercontent.com/img/b/R29vZ2xl/AVvXsEiuYEsv42HuGOyfG3WUHp4IXCnQrEGNzpTMxDv8YMWlwjQCXfmkd1m3wVRInOXF4Rp2JvsEOQcfXb0mYnmQaBFHeSE7ZE9eY2xd_BouDBexGCco4NgHsAWx7fwqqM7PdCkbohZn0cpa/s320/dsc04749.jpg)
![](https://blogger.googleusercontent.com/img/b/R29vZ2xl/AVvXsEgiAbgD7ZAXKALAxN5NzRQHCkRv6jdf-4x4jsBCOHhyphenhyphen2UKbN-fxxtMidXYZIvIZSxZzJ9uGvHiZD1g2W8lPLrDMPHFaFzjfpOMnF0GhnUWRF20qKn_cwP2dzbvClb45Iq9qlVTMOhpb/s320/dsc04750_cropped.jpeg)
![](https://blogger.googleusercontent.com/img/b/R29vZ2xl/AVvXsEiXRf8P_sP3Bz6t7IuWjJd6el2JTv_cXhs1tYFirwHF5LVoC1aRY23B97C1Wucnup8l34H7cmYJfYiAQU7recZvGoTAyi7IjJONE-56y0r8vFCWgxn3UZKfvv36Rgog2330cAFF7XGa/s320/dsc04752_cropped.jpeg)
![](https://blogger.googleusercontent.com/img/b/R29vZ2xl/AVvXsEj-rgnzm4YzHwyfVcmAwOtmEb5OQ369Zg4ozWjbzrAdMIaW7XLwGPbOhh_8IU0QqRzJxp5p9GI75DIBQKUi82g0XoBOekxyMENqHWxCMJ2w9kO1q4jBx9vBB-LKoPjQ2FeZfk_H2L2n/s320/dsc04753.jpg)
Insulate with kapton tape, add 6-7 ohms of nichrome wire near the nozzle, insulate again. That's your heater.
![](https://blogger.googleusercontent.com/img/b/R29vZ2xl/AVvXsEjlhNuBlxgdtFuTOrhXNid3L9cCLPc9X66r1_unzRyDK6ppE8nYA38q3iYreEiX85Zx_Sg5YbWSc_gATPRqtwyGwzhAmXh6eHrKgqX1Pv649Uxnemb1Dsv3BfLyVrupxDrYfLOO8-4-/s320/dsc04755.jpg)
Slip 10mm of a 25mm length of 3mm ID silicone tube over the open end of the barrel and clamp it all in MDF. I found it necessary to add an MDF slip over the top part of the silicone tube later on to stop the soft plastic bulging within the tube. I used bolts to connect up the power to the nichrome and kapton-taped a thermistor probe to the side. The combination works well up to about 180C with PLA and is stable at temperatures of up to 300C by which time the PLA starts coming out as smoke rings. Surprisingly, the silicone stops the MDF from burning.
So there you have it. Easy to get bits, easy to make, no lathing.
Labels: heater, no lathe, nozzle, reprap
Nice work.
I found that you can get brass tube from model shops about that diameter. I was fiddling with external nozzles, though - I like your solution.
a pipe clip could apply some pressure to stop the tube pulling out.
The 'lathe' problem is significant for those of us without access to machine shops - thanks :-)
Brilliant work on simplifying the process. The less specialized tools needed the better. I consider myself a crafty person but have no access to a lathe. Cheers!
@Adrian: From the picture of the nozzle in the barrel, it looks like the fire cement might be used to hold the screw in place.
Adrian. Pretty much. The nozzle/grub is just held in place against the shoulder of the tube by gravity, a little bit of wedging by some PTFE tape (not fire cement, sorry Jay) and the force of the incoming filament.
If the barrel isn't loaded, it is possible to smack the thing hard on a wooden block and extract the nozzle, or after use to push it back out from the other end to maintain it.
Vik :v)
Vik :v)
