Monday, May 19, 2008
Progress with ABS
			  I have developed peelable rafts and a reusable bed for ABS: -
That has enabled me to make these Darwin parts before my extruder broke again: -
Details here: hydraraptor.blogspot.com/2008/05/stepping-up-production.
Labels: ABS
				Wow, that looks really high quality? Have you consider making one of each individual part so  you can do molding of the rest?
				gene,
No I think that kind of defeats the purpose. I strongly believe that anybody only needs to print three sets and soon everybody that wants one can have a set and do the same. I had a ginger beer plant when I was a young kid and soon learnt about 2^n replication.
Molding is fast but quite labour intensive. RepRap is slow but you can leave it going all day and come home to find a neat line of objects. My machine is smaller than Darwin but I can still make 3 corner blocks or 7 diagonal tie brackets at a time with big enough gaps between for the head to get in so they can be made one at a time in case of power cuts or break downs.
				Amazing stuff! I can't wait for reprap to reach 2^n (even with N as months... it'sw very exciting!)
-Leav
			-Leav
				Nophead:
Reading some of your blog, it occurs to me that you might want to make yourself a DSC. They're quite simple in principle, and the only drawback to building a crude one is needing a larger sample to get comparable resolution.
It would help you in identifying polymers, and give you more data on specific heat, critical temperatures, etc.
				Oh, yes.
In the case of inorganic fillers, you'd most likely see a linear signal from the filler (chalk and titania and glass all lack phase transitions at such low temperatures), plus a nonlinear signal from the polymer.
For varieties of polystyrene (ABS, high-impact, hot glue...), you'd see a signal from the brittle PS phase, and a separate nonlinear signal from any rubber filler.
It should be fairly straightforward to fit these mixed curves with a program like LabPlot, to get a notion of relative quantities.
				Just to clarify: When I say a separate signal, I mean a signal that can be separated mathematically, not one that will enter your computer by a different channel.
