Wednesday, November 14, 2007
Extruder output profile
			  Trying to nail the parameters on the Bath Darwin, I realised that the only factor I'm flying slightly blind on is the output of the extruder. Here's an output profile for Capa using a target temperature off 100 °C and a ø 0.4mm nozzle for a variety of motor speeds.
WARNING: 12V motor used in this test. (i.e. Don't put 12V through the standard issue 6V motor!)
				So am I reading it right that at maximum settings you can push roughly 10 cm^3 of CAPA through your Mk II per hour?
				What's the total volume of the RP Darwin parts? Somewhere around 1000cc? So the current Darwin "gestation" time would be roughly a week, assuming continuous operation.
				PLA Is currently coming out at 5cc/hr, but could probably come up to 8-10cc/hr-ish too.
Oh, looks a lot like there's a repetitive sinusoidal component there.
Mind you, enough beer and anything looks sinusoidal...
Vik :v)
Vik :v)
				Hi Vik,
... i thin there are two possible sources for the sinus: first the rotating/pressing of the thread, second the temp-controlling process ...
Viktor
Viktor
