Sunday, July 16, 2006
Making interchangeable nozzles.
			  I'm making a variant of the Mk2 extruder nozzle that can be easily swapped out for unclogging, different extrusion diameters and so forth. Details can be found here, and this is a photo of one fitted to a heater barrel:
The heater barrel itself is wrapped in pelican wire - insulated nichrome. I'm using 16mm PTFE rod so I can get higher pressures. The 10mm rod didn't grip the barrel tightly enough when I cranked up the pressure for really small holes, even when I'd put a hose clamp around it.
Vik :v)
Vik :v)
				That pic belongs on the front page!  How's that insulated nichrome working for you?  Is it worth buying more?
				I've not powered up the heating element yet; I ran out of weekend :)
I'll put an amp or two through it the next chance I get, and see what colour it goes.
Once I've got the thermistor in there (Suz should be picking them up from the city this lunch break) I'll clad the thing in a nice, warm plaster and fibreglass jacket and we'll really see what she can do.
But before all the complex stuff, I think Adrian would like me to have a go with the improved infill code.
Vik :v)
Vik :v)
