Saturday, January 31, 2026
Presentation From Everything Open 2026
The organizers of Everything Open 2026 in Canberra earlier this month have kindly made a video of the talk and slides available. Damn, it's come a long way in the last year.
https://youtu.be/dq_ZCf0-KmM
Friday, January 30, 2026
Full RepRapMicron V0.05 Axis Driver Instructions Available
I've been assembling, photographing, documenting, and testing the V0.05 RepRapMicron Axis Driver. Please have a look and pass comment.
The instructions are at https://github.com/VikOlliver/RepRapMicron/wiki/Maus-Axis-Driver-Construction
The pre-built STLs are here https://www.printables.com/model/1577934-reprapmicron-v005-micron-accurate-axis-driver
Tuesday, January 27, 2026
Accidental Stress Test Of Backlash Band Hooks
So, what's wrong with this picture?
Peer in and observe those little yellow hooks at the bottom of those bands. Now observe the diameter of the blue pillars. Yes, that's right. The hooks do not fit into the gap between the pillars!
This is because doofus here reused some pillars off an old axis, and didn't check to see if they were the ones that were compatible with the new hooks.
Net result is that when the Drive Screw attempts to lift or lower the yellow mechanism in the middle, it tries to snap the hooks off. Well, the good news is that the yellow bit canted over and snapped off its flexures before the hooks came off, so I guess they're strong enough...
Now of course I have to reprint all the bits, reassemble them, and redo all the pictures I took with the wrong pillars before I can finish the build docs. *Sigh!*
Monday, January 26, 2026
V0.05 Axis Driver Assembly Hint - Band Retention
If you're assembling a V0.05 Axis Driver, insert all the nuts, then put the silicone bands on. You can hang them up out of the way on a couple of screws like this:
 (The blue bit and 50mm M3 screw was added after I'd hung the bands on, but it propped it up at a photogenic angle...)
Then you can pull them over the top of the Nut Bar once it is in place over the Drive Screw.
Saturday, January 24, 2026
Back From The Land of Oz
Back in NZ. μRepRap is in bits in the suitcase. It survived the outgoing trip well, and the Everything Open trip was a success. Might be doing some colabs on YouTube, and there is a video that is going up (and I quote) "soon." Last time that meant six months...
I'll post the slides once I've sorted my unpacking.
Footnote: The X and Z axes got smashed on the return trip. Nothing 16 hrs of 3D printing can't fix, but the machine will be down for a bit.
Sunday, January 18, 2026
MAUS 'L' V0.05 On Holiday In Canberra
Time for a hotel room reassembly session. Updating the github wiki on V0.05 as I go. Fortunately I also took this photo of the RAMPS board wiring.
Thursday, January 15, 2026
Gold and Joysticks
The gold has turned up. Small flakes rather than sheet, but we'll see what tests can be done. Also in the package was vark, or edible silver foil. The μRepRap is now in bits in the Everything Open suitcase, so testing will have to wait. Back in 10 days, got a house-sitter so the pets have good company.
Will post snaps of Maus on holiday.
Meanwhile Siddharth has published his joystick control code for μRepRap, so that'll be something else to play with. Should be more accurate than trembly hands, with less opportunity to wreck things when waving stuff around. I've checked and I can just about get Maus under the binocular microscope, giving a view in 3D.
https://github.com/Siddharth2308/RepRapMicron/blob/main/Joystick%20Control/gamepad.py
Saturday, January 10, 2026
Exploring Layer Failure Modes With Wrong Starting Height
This image shows a 1000μm (1mm) long, 5-step staircase. The treads are 200μm square. Each step is 5μm (notionally) taller than the step to the right. Top right above the staircase is a series of 10 dots. These were used in an attempt to determine the probe height empirically:
As you can see (now I have my gimbal slide holder and the new microscope imager going) it has gone all blobby. Now, when initially trying to determine the probe height manually, I ran some GCODE that did 10 dots, each one 1μm lower than the previous one. Through the USB microscope, I could only make out the last 7 dots and so lowered the probe an extra 3μm, but as you can see I was in fact already in contact. This put the probe at least 3μm too low when commencing the first square, and things got horribly chewed up and uneven by the time we got to the 20μm tall square.
If you look at the top edge of the staircase, you'll see an indication of the change in step height. The random small blobs scattered around are where the probe lifted from the surface to recharge the probe. These may decrease if I get the height right.
Anyway, if I can't show you something going right, I can at least show you where I'm going wrong. If I write it down, it's science...
I'm going to have to take a break now to prepare for a μRepRap presentation at Everything Open in a week or so.
FYI Probe 9, 2.3μm layer height, 34μm line width, solid infill, lines drawn as segments not dots, 150 x 15μm segments (2.25mm total linear distance) deposited per probe "dip".
Thursday, January 08, 2026
Kinky Probe, Gripping Things, And New Foil Slides
To keep the angle of the point with the slide more vertical, I've put a kink in Probe 9. This keeps the width of the deposited line even regardless of the direction the probe is travelling in. One question I has was "Will the resin still climb the probe?" and the answer is yes. As you can see here it still accumulates nicely. Unfortunately the probe was a bit close to the edge of the foil, and this resin is mostly set solid:
Note that the probe still worked to some extent in this condition. I'll get it off by soaking in acetone, which has worked previously. This illustrates the importance of placing the probe's dipping point at least 0.9mm back from the edge of the foil, and preferably with the UV LED underneath the foil to avoid UV casting up onto the side of the probe.
The slide in this case was made using adhesive aluminium tape approx 60μm thick. The assembly process is as follows:
Clean slide with a razor blade and isopropyl alcohol to remove previous experiments. Cut a piece of adhesive foil on a cutting mat with a small box cutter approximately 1/3 the length of the slide.. It is important to cut the foil shiny side down.
Stick the foil on one end of the slide, leaving a 3mm gap to the end. The gap is so that the slide can be placed in a slide storage box after experimentation. Place a piece of printer paper on top of the slide and burnish the foil flat using a cylindrical polished chrome burnisher - I use the hex bit adaptor from a set of drill bits.
Place a second glass slide flat across the first perpendicularly and drive it in short motions against the edge of the foil. This curves the edge up slightly, creating a retaining wall for the resin.Run an isopropyl-dipped cotton bud up and down this edge to remove any exposed foil adhesive. When doing this, press the cotton bud against the edge of the foil laterally to give the retaining wall a crisp edge. The slide is now ready to be used as per the previous version, but the Touch Plate Height will need to be adjusted as the foil is thicker.
This is quicker to construct, and less prone to the probe tip penetrating the foil. It is, however, not as consistent, and I have found that making test dots of resin with the probe is the only way to be sure of probe height. It also tends to be more wrinkly, and might benefit from burnishing before adhering. However, if the wrinkles are not near the actual reservoir they are unimportant.
I have made another prototype gripper. This one is 13x larger than the one I intend to micro-print, which in this configuration would have a jaw spacing of 230μm (example has 2mm spacing, corresponding to 150μm). Obviously a version with wider jaws that don't completely close is possible. The hypodermic body and plunger would be replaced with a 0.5mm hypodermic needle and 0.23mm wire, assembled manually (I may add alignment stops). The actual actuator is undefined at this point but I has ideas. This one is a bit prone to torsion of the plunger, the plunger anchor is too short resulting in some curl, and the jaw tips need to be taller for more gripping area. All of these issues should be fixable. As it stands, it can grasp a sheet of paper and drag it along the desk.
 With minor changes it can be modified to close when pushing or pulling the actuator.
Monday, January 05, 2026
New Optics For The Lab
I've got a Svbony SV205 "8Mpixel" imager. It's a YUV USB3.0 device so it plugs in to Linux and just works. Unfortunately it didn't plug straight in to the Kronus trinocular microscope, but a few hours later I'd modelled an adapter that I'm almost happy with. The plastic shell wasn't sufficiently lightproof though, so I added some aluminium tape (which, yes, I will test as a slide touch plate at some point).
Notice how the USB lead wants to pass between your eyeballs when the imager is in the correct orientation.
I've not played much with the lighting and so forth yet, but I took this screenshot of the calibration slide while fiddling around. The squares are 50μm and the linear divisions are 10μm. Looks like I may have a bit of tilt in my adaptor as the left side is a bit out of focus. Unlike the phone camera there is no clever filtering and pixel-guessing going on, so it looks a little drab.
3D Files for the adaptor are here https://www.printables.com/model/1544204-svbony-imager-to-konus-microscope-adaptor
Saturday, January 03, 2026
Poor Results From Gold-ish Leaf (Dutch Guilding)
Did a quick experiment with some Dutch Guilding leaf to see just how conductive it is. I put some nail gel on a slide, placed a sheet of paper on top, and used a cylindrical burnisher to rub it down. The idea being to form a thin layer of resin, which I then set to hold the guilding in place. Looks nice and shiny:
However, Dutch Guilding is thin sheet brass, not nice malleable gold. It did not conduct at all - look close and you can see where I was poking in vain with a multimeter.
Zoom in with the microscope and we see why:
It is just a maze of little cracks in there. With real gold you'd be able to burnish it out, or meld another layer on top. Worked brass is brittle and just breaks up. Its oxide layer prevents melding.
I need gold. Gooooold!!!
Thursday, January 01, 2026
The Great Pyramid Of Phail
Happy New Year!
The hand has healed up enough to make more slides, so I printed all the ideas I had kicking around while convalescing. I tried a few 200μm diameter micromugs, which ended up being dog bowls again, and a chain of hinged squares to test multiple folding. I'll cover that in a later post when I've origami'd it.
But the main push was to try and print a pyramid, on the grounds that they're infamous for standing up. Mine was 400μm on each of its three sides, and 300μm tall, making it the tallest and largest thing I've tried to print.
Of course, it didn't go as expected. It looks like it's spent 10,000 years in a rough desert and learned bad things from a ziggurat:
It didn't help that I probably started the probe a bit too low either. My guess is I need to get the layer size (2.5μm) down even further to make sure there's enough resin in the middle of it, maybe adjust the print width a little lower too. However, it did print all the way up even if it did sag like a poorly-baked cake! Where the print is sliced a little denser at the top and the corners you can see some facets trying very hard to happen.
The UV cured the resin from underneath too, so that answers whether the underslung tiny LED can cure relatively thick layers of resin.
Other good news, the printer stayed together throughout the entire process, and the resin was in the reservoir was still perfectly good after all the exposure to air and scattered UV. I should point out too that this was printed using short segments rather than dots of resin. That is significantly quicker to do. It would be interesting to compare the dot-by-dot approach for quality at some stage.
Why is it dark grey? It isn't. That's a refraction of the black microscope stand underneath. Doesn't it just highlight all the defects beautifully? The resin is actually quite dense and optically good, which is why I think I need to just make the layer spacing a bit thinner. Could probably print simple optics. I'll finish off with a shot taken straight down onto the frosted glass surface:
Comments [Atom]
