Friday, November 07, 2025
"Dipify" GCODE converter Now Supports Layers & UV
No image to show, this is all software. The new dipify PrusaSlicer filter is now on github https://github.com/VikOlliver/RepRapMicron/blob/main/gcode_segmentation/dipify_gcode.py
It now handles layers and turns the UV LED on between them. There is also a scaling factor to deal with PrusaSlicer's assumptions about how big extrusion widths and layer heights can be.
All the parameters are internal, but I've started adding an argument parser. It's not actually used or called yet.
I've run it through the V0.05 hardware dry, and it doesn't seem to do anything particularly stupid. Now to get the probe and slide hardware sorted out as per previous post so that I can do some layers. That's going to take a day or three...
