Monday, August 11, 2025
XY Table V0.04 Flexure - First Hardware Attempt
I had to shift the V0.04 supports for the Table Flexure outside of the flexures because of collisions. So the points where the frame and table flexures join is now an enclosed joint. This means the screws are an essential part of the flexure attachment point, though this shouldn't be a problem.
Dimensionally it's the same size as the V0.03 frame, so replacement should be straightforward if tedious. I'll swap it in, do a quick bit of testing and I'll upload the files. Maybe I might upload the files earlier if anyone asks.
