Tuesday, August 12, 2025
V0.04 Flexure Table Source And Assembly Docs On Github
I've uploaded the V0.04 XY Flexure Table source to Github. As you can see in the image below I've made the Table Frame attachment points wrap around the shelf on the Outer Frame. I've also added captive nut cavities because it was a pain in the ar...mpit to get the nuts into place when modifying the completed assembly.
I've started putting the V0.04 modifications onto the wiki as a separate section https://github.com/VikOlliver/RepRapMicron/wiki/V0.04-Upgrades because I don't want to be constantly modifying the V0.03 text and images as I make incremental improvements. Once I've printed the latest Table I'll upload some images and assembly docs, then annotate the V0.03 docs to indicate that there's a change. This will be the process going forward through V0.04
I've not updated the STLs on Printables. That'll happen when I know they work. Should I upload them as a separate item on Printables in the meantime anyone?
