Tuesday, April 30, 2024
Second Crack At Logo
Getting closer. You can see the 'u' if you squint...
Getting the Z height right is the tricky part, there being no bed levelling. I'm not sure what increment to move the Z axis down at. Might set up a file that draws a square moving down 0.001mm per corner and keep doing those until I hit the surface.
Other developments: UV LED turned up, and it sets the resin I've got. Using the UV hole to illuminate the slide from underneath with white light helps too - I just put a piece of white paper under it and shine the side microscope LED onto the paper.
