Tuesday, December 27, 2011
0.01 Layer Height on a Prusa Mendel
After a very long time sticking with Sprinter Firmware and Sfact for my Gcode generator I decided to upgrade a little bit.  I moved to Marlin Firmware (Which has became all the rage in the RepRap IRC Channel), and Slic3r for Gcode generation (Does same job as Skeinforge).
Marlin is a litle more confusing to set up than Sprinter (Configuration.h is modified by commenting in and out things instead of setting variables).  Only real change I have found with Marlin is acceleration has a different sound to it, and my rounded parts are a bit more round.
Slic3r is amazing.  STL that would take 30-40 minutes to convert to Gcode it can process in 2-4 minutes (The .01 layer height woman only took around 8 minutes to slice and would have been over an hour with sfact/skeinforge).  Also, setup is dead simple.  Just enter your nozzle size, filament diameter, and extrusion multiplier if you e/steps are a bit off and your good for a 1st print.  Only downside of Slic3r is it does not support single wall prints, or support material yet (But if you like to play with code I am sure Sound would like the help on hit Github, or the slic3r IRC).
For ultrafine printing with Slic3r the only parameter you change is the layer height, So both the failed Yoda at .04 and Pink Panther at .01 only required a change from .25 layer height to .04/.01 respectfully.  The Yoda failed because at such fine layer heights I discovered that bridging is completely broken, so any small break in the outer skin of a part will never get fixed by the bridging of the next layer and just get worse over time.
After the failure of the Yoda I needed to find a model that looked nice in fine printing, and had no bridging, of course my mind went straight from Yoda to the naked female form.... don't ask.
Printing at this layer height really shows off that I need to upgrade from standard Prusa Z couplings to a Nophead or aluminum Z coupling, but beyond that the print turned out wonderful.  at .01 layer height as you can imagine the 1st 2 layers where a bit sketchy, took me 1 hour to get the bed THAT level (1/25 your normal layer height really shows you how not level your bed is).
From talking to some friends in the RepRap IRC I think that with 3mm filament .01 layer height will not be possible, just because the feed rate would actually be too low, and the retractions would cause you to repeatedly go over the same piece of plastic, causing the plastic to shred.  But if your running 1.7 plastic and Slic3r repeating this stunt should not be that hard.  Hope you have a lot of time, it took 9 hours to get of to the upper chest on this print before I ran out of Z. :)
Equipment/Software used:
Makergear Prusa Hybrid
1.7 Red ABS Plastic from Ultimachine
Marlin Firmware v1
Latest experimental branch Pronterface in Linux
Slic3r GCode Generator v5.7 (Fully stock settings besides layer height at .01)
3 perimiters, 0 infill
Saturday, December 17, 2011
Solving a nagging question about print adhension
In which a long term question about print adhesion to an acrylic print table is answered via thermal imaging.
Do you want to read more?
