Saturday, April 03, 2010
Hot copper and PLA
Acting on a suggestion from Vik, I have found that PLA can be extruded onto copper clad board and, if it is hot enough, it sticks very well. I have to flex the board to remove it. 55°C is too cold but 130°C works well. I haven't tried anything in between yet.
Assuming PLA will resist PCB etchant, this could be a way of making PCB's without a laser printer, albeit quite low resolution. With 0.3mm filament squashed to 0.24mm a single line would be 0.36mm wide, which is 14 thou.
It also seems like a good bed material for making PLA objects on.
More details here: hydraraptor.blogspot.com/2010/04/cu-pla
Labels: , , ,
im actually using a FR4 copper board on my Makerbot as a surface for heated build base, the temp needs to be higher, but it works very well. I have a bubble etch tank, will try this later! ive also tried putting a dremil onto it to see if it could mill a pcb - results good, tho a bit curvey!
roboteernat.blogspot.com
Nat
Cool.
I´m at Easterhegg, we have a RepMan,
the heated copper-board from my own
RepMan (tMax currently 65°C but we can "overclock" that up to 200% to get higher)
and a lot of PLA from the Makerbot on the next table.
I hope we can do a test-series tomorrow.
Marcus
Comments [Atom]
