Thursday, January 10, 2008
Segment pause bug-fix committed
Some new properties for you for the latest SVN:
Extruder0_ShortLength=1.5
Extruder0_ShortSpeed=1
Extruder1_ShortLength=1.5
Extruder1_ShortSpeed=1
Adrian's new code speeds up the nozzle for short segments. This work-around massively improves previous problems caused by segment-pausing (the pause between segments was causing a noticeable extrudate dump between short segments, over a radius for example. The new fast speed option evens things up a lot).
Temperature constraints for the extruder in GenericExtruder.setTemperature() have also been tightened from 10% & 20% to 3% & 6%.
Happy printing ;-)
Happy printing ;-)
Labels: bug-fix, extruder, Segment pausing, ShortLength, ShortSpeed
I'm printing a Z Pulley Rim with this now, and it's looking good. I might be able to speed up printing a fair bit with this now that printing at speed has less variation in line width.
I've also found the FastSpeed variable in reprap.properties, which might help reduce stringing.
Vik :v)
Vik :v)
