Saturday, December 15, 2007
Print Head Auto-Encapsulation
This is going to be a complete bugger to chip free. I'll probably bake it at 150C for a while and pull all the crud off. The cable tie and terminal block will melt, of course. At least there is a thermocouple conveniently embedded in the blob. The girls, however, want me to preserve it as a memento so I may have to build a new one.
How the heck? I left the thing running overnight doing an X Axis Constraint and a serial error caused it to stall with the extruder motor and heater running.
Vik :v)
The solution to that is, of course, to change the code from "Do this until you are told to stop" to "Stop unless you receive the signal to continue".
Either approach requires some feedback method for checking to see if one should continue. Is there any motion checking device in place? Maybe a periodic clock to see if the endstops have been hit at least every so often?
