Thursday, January 24, 2008
Another pile of parts falls out of the RepRap
Due to popular demand (Hi Adrian!) here is another snapshot of the parts fabricated so far, including the extruder made on Zaphod. You may note a few other additions - opto brackets, bed corners and XY idlers - have joined in. I've been eating up the filament from Imagin Plastics in Henderson like it was spaghetti, and may well have to go back there cap in hand. I do have enough to finish fabricating this RepRap and to feed it well enough to make the next generation. CAPA supplies are coming soon, so I might have a go with CAPA extrusion again later. See you in just over a week!Vik :v)
Wednesday, January 23, 2008
Update from he who feels like hammered sh...
I've taken the cutting board off the RepRap and given it a damn good sanding flat, checking it with a steel ruler like my old Design & Technology teacher showed me while I was busy wrecking his workshop. Adhesion improved, particularly for large areas. Not managed to print an X Motor Bracket properly yet.
The Y Bearing Housing I printed the other day broke when I put the insert in. I found that there is an area inside that gets no infill, and so the part is really fragile. I narrowed it down to a pretty damn minimalist debuggable shape and sent it to Adrian, the internationally famous geometry guru. A mere 8 points or 12 triangles.
Brain currently fried due to insomnia, my back is aching like hell through painkillers, and LinuxConf is less than a week away. Ohboy.
Vik :v)
Vik :v)
Tuesday, January 22, 2008
On the road to replication
Ed tells me that my Darwin is now extruding at half the speed of the Stratasys FDM machine - albeit at a lower quality. Once I've replicated my combined output will be approximately the same as said machine with significantly less outlay. So, if you're wondering how many RepRap bits I've actually made from PLA, and hence how far off replication we are, have a look at the picture.
There's a variety of different versions of software in use, with the old ones looking distinctly lumpy, but the parts are functional.
Vik :v)
Monday, January 21, 2008
Extruder feedback
The RepRap electronics already have the facility for extruder feedback but we haven't got round to implementing it yet. Today Adrian and I got onto it. We decided to go for a fringe for the drive cog. While this wont pick up backlash it does have a much higher capacity for resolution.
In stereo - another opto bracket
Following in Ed's footsteps, I've run off a copy of the opto bracket in PLA. The build time was 51 minutes, extruding at just under 140C. Looks good from here.
Vik :v)
Sunday, January 20, 2008
Optoswitch bracket printed
There's not enough time-lapse in the world, so here's some more. Plus some Aerosmith because there's not enough of that either ;-)
Z Axis Kebab Printed
Just finished a Corner Bracket, Bed Constraint Bracket and its insert. I've stuck them all on the same rod, and the centre of the insert does line up with the corner bracket's hole. Bolts are now sliding in without having to attack things with a power drill.Missing from the collection is the Z studding tie, which gives our software a little trouble - Adrian is working on it. Meanwhile I'm extruding Darwin parts with my PLA extruder on Darwin at just over 4cc/hr.
And just for Ed, another close-up shot of that corner bracket.Vik :v)
Friday, January 18, 2008
Extrusion at different temps
For a speed of 188 (8.81 V) on the Solarbotics 12V version of the GM3 motor, I tried extruding CAPA at different temps. Temps are recorded using the extruder's thermocouple:
It's good to see quite a tight distribution of trends here, as high filament temp eases the load on the extruder, however, it's worth bearing in mind Vik's previous comment: "Be wary of running over 100C. If your plastic has absorbed moisture, you may get steam bubbles. If they're small, no problem. If large, they interrupt the feed of fine extrusions."
Geared extrusion
Adrian and I designed this gearbox today. We made it on the Strat too, coz RP's good like that. It includes brass bushes for the gear bearings and bought in MOD gears. Previously, using the 12V Solarbotics GM3 motor, I'd been getting stalls at low speeds. This new arrangement safely cuts output rpm down to a third, which, I'm hoping, will give the other parameters a bit of breathing space. We shall see...
Wednesday, January 16, 2008
Darwin on CAPA
While Vik's been blazing trails with PLA I've been trying to get our Darwin to follow suit with CAPA. Finally, the variables are coming together, and last night we printed it's first part: the y-belt clamp. I'm proud to say that this is what it looks like straight off the bed, no post-processing needed, and the M5 bolts screw straight in! (1 small square = 1mm)
My best lessons so far have been getting the temp relatively high, ~130°C (to reduce extrudate viscosity and prevent extruder stalling), and to spend time getting the layer increments spot on (to guarantee layer bonding). I'll upload my variables today into the 'tweaking' section of the wiki.
Sunday, January 13, 2008
Bed Corner and Diagonal Tie Bracket
Here's the Bed Corner mounted up with springs & nuts on a piece of studding. On the bottom of the studding I've stuck 2 Diagonal Tie Brackets. The top one - from Steve's no-overhang STL - is printed using the new software and has not been manually tidied (though I did have to warm up the retaining nut to get it in), the bottom one was done with last month's software and has been tidied. Adrian's latest fixes have made quite an improvement in quality, I'm sure you'll all agree.
Sadly, printing Corner Brackets in fine detail seems to cause a new bug so no more of them for a little while. But I'm off to Wellington in a few days anyway, and I'll be taking Darwin with me.
Please ignore mess at "dirty" end of bench...
Vik :v)
Saturday, January 12, 2008
Bed Corner Printout Success
It took me 3 goes. One cable pulled, and a stuck filament roll; but I got it printed in the end. Thanks to Steve for helping with the STL file. The object took 5.8 hours to print in PLA using Darwin hardware and Adrian's latest fixes. It has really picked up steam now and the quality has improved as the nozzle moves faster - as predicted.
No hint of curling on this part either.
If you look inside the holes on the left, you can see some stringing, but it is now more like annoying cobwebs than a barrier that needs drilling out with a cordless drill. Just as well - I did stick an 8mm drill bit in my hand last time.
Here's the view from above, with a clearer view of the stringing. The thick stuff is caused by a plotting error we're looking into, and the fine, spider-web stuff is what the more persistent stringing issue now looks like.
I've tried to bend the part, and it doesn't break despite the plastic flow being a little low, so we should be good to give it a go in a real Darwin.
Vik :v)
Labels: bed, corner, darwin, pla, reprap
Arduino Firmware v1.1 Released
Yay! I finally got non-sick, non-busy, and non-not-in-New-York and got a few hours to sit down mano-a-arduino and finished the RepRap protocol integration. The hardest part and biggest challenge was implementing the Celsius -> PIC temperature reading (as well as PIC temperature reading -> Celsius). Thanks to Steve DeGroof, I was able to plug some values in for an 'ideal' thermistor and everything worked like a charm. The PIC emulation is accurate within a couple degrees at the high end (250C) and within a few tenths on the low end (room temp).
What this all means is that the Arduino based electronics are now 100% compatible with the current host software.
For all those who are using the Arduino based electronics, its *highly* recommended that you upgrade (otherwise, they wont really work.) Here's what you gotta do.
1. download the new firmware from SourceForge.
2. copy the library files from the firmware .zip into your arduino's library directory. overwrite the old libaries if you have an older version of the RepRap Arduino firmware.
3. update the firmware and host software prefs as per the wiki.
Thats it! If you have any questions, bugs, or suggestions, let them fly in the comments.
Friday, January 11, 2008
Advanced Electronics Thoughts
I've been thinking a lot lately about the Arduino and some of the cool advanced things we could do with it. Some of it was spawned by threads in the forum about servos vs steppers and some of it was because of some problems we've been having with thermistor style temperature measurement (blown thermistors, inaccuracies at high temps, etc.) Anyway, I've been working on a couple new circuits that have the potential to be very useful.
Thermocouple Sensor
This one is a high quality temperature measurement board based on the AD595 chip. It uses a thermocouple to measure temperature, and is specifically designed to be used with Type K thermocouples. The nice thing about a thermocouple is that they can withstand *very* high temperatures. The type K thermocouple is rated for up to 1200C. Thats hot. The sensor board is really just a PCB to house the AD595, an LED, screw terminal, and the interface pins. The vast majority of the work is done by the AD595 which takes the signal from the thermocouple and converts it into an output that is ideally suited for an ADC converter. The way it works is that the AD595 outputs 10mV/C... which means that it is *very* simple to convert a reading from a thermocouple to a Celsius reading.
The circuit is mostly done, but I'd love to get some feedback before I have a prototype run made. Given the small size of the board, a prototype run will still be 100+ boards. Anyone want one to play with?
All the Eagle files are located here: http://svn.reprap.org/trunk/users/hoeken/arduino/electronics/thermocouple-sensor/
Magnetic Rotary Encoder
A rotary encoder is a circuit that allows you to precisely know the rotational position of something. In our case, we'd use it to know the exact position of our motor. This one is a high precision rotary encoder based on the Austria Microsystems AS5040. It uses a magnet on the drive shaft, and a chip that detects magnetic fields (the AS5040) to detect and tell us exactly what position it is in. The AS5040 offers 10-bit resolution (1024 positions/revolution) and offers a TON of outputs: quadrature encoding, PWM output, analog output, and a shift register style output. This board takes the AS5040 and brings all the outputs out to us so that we can use the one that matches our needs.
This circuit is less done. There are still some things to be done in the schematic (help/feedback wanted):
* add a power-on indicator (good idea?)
* add a calibration LED based on using a single pullup with the maginc/magdec pins (not sure how to do this)
* needs to be laid out properly and in such a way that its as small as possible
* figure out the best way to put mounting holes on to make it as easy to use as possible... (right now i'm putting 4 holes... one on each corner.)
All the Eagle files are located here: http://svn.reprap.org/trunk/users/hoeken/arduino/electronics/magnetic-rotary-encoder/
Keep in mind these boards would be intended to make it easier to for people to build and experiment with more advanced technologies that will hopefully someday become part of a core reprap system. Its still very early in the game for these boards, so any feedback now will be greatly appreciated (and used!)
Thermocouple Sensor
Corner Bracket photos and Bed Corner
Here is the shot of the two finished corner brackets. The furthest one has been trimmed of string, the nearest has not. They seem functional but I need more to know for sure.Note how the holes in the sides have been sealed off by stringing. This problem has since been much reduced.
Here we have the start of a Corner Bracket (that died 1 min after I took the photo due to me tugging the USB lead out). Steve DeGroof kindly modified the STL file so that it will print without support material and so I decided to give it a whirl. The RepRap is running much faster following Adrian's recent changes to speed corners up, as I have been able to raise the speed in general.Two other milestones: The communications now copes if you disconnect the serial lead and reconnect it again - though not so happy if you disconnect the USB lead! Also I've now printed with over 100m of PLA filament.
Vik :v)
Thursday, January 10, 2008
Segment pause bug-fix committed
Some new properties for you for the latest SVN:
Extruder0_ShortLength=1.5
Extruder0_ShortSpeed=1
Extruder1_ShortLength=1.5
Extruder1_ShortSpeed=1
Adrian's new code speeds up the nozzle for short segments. This work-around massively improves previous problems caused by segment-pausing (the pause between segments was causing a noticeable extrudate dump between short segments, over a radius for example. The new fast speed option evens things up a lot).
Temperature constraints for the extruder in GenericExtruder.setTemperature() have also been tightened from 10% & 20% to 3% & 6%.
Happy printing ;-)
Happy printing ;-)
Labels: bug-fix, extruder, Segment pausing, ShortLength, ShortSpeed
Tuesday, January 08, 2008
First Corner Bracket
OK, so I have a Corner Bracket in PLA. Took about 10 hours to print. I'm trying a second one now, just to make sure it's not a fluke. I'll update with photos later.
As it comes out of the RepRap, the stringing within the part obscures many of the holes, and drilling is required to make the part usable. Is this considered minor refinishing? A cordless drill with 8mm or 5mm bit basically guides itself into the right position; I just hold the PLA bracket in my hands and try not to drill my fingers.
Blobs are apparent at the end of each layer, when the nozzle halts and the RepRap software figures out the next one. The nozzle oozes.
The Corner Bracket has rounded corners which will not print without overhanging, and these cause knock-on wall collapses up the side of the corner bracket. It would be better if the corners were square.
Mid-way up, the distance between hole and corner is quite small. This results in a rather fragile-looking corner. This would be strengthened by leaving the edges square, but an extra mm of wall thickness wouldn't hurt either.
Is it strong enough? Just, I think. For the moment I'll call it good enough to try and build another Darwin with. After a week I should have a full set of Corner Brackets!
Vik :v)
Vik :v)
Sunday, January 06, 2008
PWM Driver v1.1 / DC Motor Driver v1.1 Released
I've finished two new versions of the boards for the Arduino electronics. These are incremental improvements that offer cool stuff like more blinky LEDs, minor fixes, and such. Full build pix, tester code, and everything you need to know to get started with these boards.The DC Motor Driver board will control 2 small DC motors (or you could drive a small stepper if you wanted).
The PWM Driver board will control 3 channels of PWM at up to 5A each (theoretically) This is used for things like fans, heaters, etc that just need to be turned on/off.
The files are released on SourceForge, the boards are for sale in the RRRF store, and everything should be fully documented. If there are any questions, please let me know in the commends!
Paste Extruder water tests.
Here's a quick video of Kate and I testing our copy of Adrian's Paste Extruder prototype. We've loaded it up with 50ml water and excessive pumping.
Adrian has also made some beta firmware that we hope to get out there soon, using the PIC16F648A CPU. I've stuck it in my Darwin and seem to be able to make things extrude.
Darwin now has a snug carry-case, and I hope to test it out on a trip to Wellington in the near future.
Vik :v)
Vik :v)
Labels: paste extruder, reprap, squirt, water
Friday, January 04, 2008
RepRap at UK Science Museum
Congratulations to Toby Borland who has recently had his wooden lasercut RepRap machine featured at the UK Science Museum. From what I gather, Toby works for SMARTlab and is doing some really cool things.You can read an article about the exhibit (how I found out about it... thanks google alerts!)
Thursday, January 03, 2008
New manufacturing process
This is not directly a RepRap idea, but I wanted to post it
1. Because it could be useful, and
2. To stop anyone patenting it if it is.
As you know, we've been playing with silicone soft moulds for making things in resin:
Suppose, instead of pouring in resin, you put a loop of wire in the cavity, flowed an electrolyte through the mould, switched on a current, and metal-plated the wire? Might it plate to fill the cavity with a metal object to match the cavity's shape, with the rate of deposition slowing as the growing surface approached the silicone where there would thus be slower flow?
Just a thought...
Just a thought...
